[Qgis-developer] Re: Error while compiling QGIS 1.5.0
mroddjob
david.thompson05 at gmail.com
Tue Sep 21 05:35:53 EDT 2010
A. Golubev wrote:
> 02.mm.2010 12:51, Jürgen E. Fischer пишет:
>> Hi Golubev,
>> On Mon, 02. Aug 2010 at 11:58:12 +0400, A. Golubev wrote:
>>> QGIS 1.4 compiles fine. Is there any solution?
>>> MinGW 3.4.5, WinXP SP2, Qt 4.5.1
>> Hm, http://lists.osgeo.org/pipermail/qgis-user/2010-April/008449.html
>> suggest
>> that this problem already existed in 1.4. I don't know if anyone tried
>> to
>> build QGIS with MinGW. The "official" builds are done with MSVC, which
>> apparently doesn't have that problem.
>> Jürgen
> I dont have "qgis\src\core\gps" dir in my QGIS 1.4.0 src tree. Is there
> any way to disable compiling of gps stuff or this is core functionality
> now? If so, I will try MSVC. Thanks for help!
> Qgis-developer mailing list
Hi Golubev,
Did you manage to get this to work?
I am having the same problem, trying to build QGIS 1.5.0 in Qt Creator under
windows xp. I get the same errors. Can anyone suggest a solution?
Regards
Oddjob
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Error-while-compiling-QGIS-1-5-0-tp5363180p5553920.html
Sent from the qgis-developer mailing list archive at Nabble.com.
