[Qgis-developer] Re: cmake error on OS X 10.6
John C. Tull
john.tull at wildnevada.org
Tue Sep 21 22:14:24 EDT 2010
I'm glad to hear you had success. I played catchup today with a bunch of stuff and ran into the same build problem you had reported. Thanks for your good research on the patch as that saved me some grief. I still managed to have a corrupt cache database and some other issues that made the upgrades slow me down quite a bit.
Good luck with you qgis work,
John
On Sep 21, 2010, at 5:54 PM, Matthew Denno wrote:
> Just a follow up. After applying the patch and upgrading to PyQt trunk I was able to get QGIS installed from source. And I learned some things along the way :)
> William and John: Thanks again for all your help.
> On Sat, Sep 18, 2010 at 11:19 AM, William Kyngesburye <woklist at kyngchaos.com> wrote:
> I just ran a trunk build from Xcode. No patches for that Qgis SIP bug have been applied yet, so I had to do that ot my local source copy to get it to compile. The PyQt bug mentioned there about utf8 *has* been applied to PyQt trunk.
> 2 ways to apply a diff: patch command and manually. Since the patch is lines of text on a web page instead of a file download, this one is simple enough to apply manually, it's just deleting a bunch of lines. Delete lines 268-318 of python/core/conversions.sip.
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100921/1d57c614/attachment-0001.html
