[Qgis-developer] gps toolbox (detect device on mac OSX 10.6.4)
Massimo Di Stefano
massimodisasha at yahoo.it
Thu Sep 23 08:25:59 EDT 2010
Hi :-)
i'm tring to use my bluethout gps device with Qgis, but it is no recognized
(there is no way in Qgis to manually add the path to device) ..
To fix i need to add manually "/dev/tty.GarminGPS10-Gps10" in : qgsgpsinformationwidgetbase.ui
(i added my device in the .ui file using "add item" in the combo box widget)
The weirs is .. after build qgis with the changes in " qgsgpsinformationwidgetbase.ui "
i have no new entry in the combobox, it is empty
but just "select the first entry (position 1 in the combobox, where i added the item in the .ui file)
it is empty ... (no device visible) but i'm able to connect to the device.
Is inside qgis a place where i can "statically" set the path to my gps device ?
Like a dialog to set manually the device address ?
(instead or in addition to choose it from the combobox, beacouse autodetect device doesn't works as aspected)
thanks for any hints!
Best regards,
Massimo
