[Qgis-developer] gps toolbox (detect device on mac OSX 10.6.4)
Massimo Di Stefano
massimodisasha at yahoo.it
Thu Sep 23 10:37:30 EDT 2010
Way lost a so cool enanchment ?
What a bout a small changes in the gui ?
the combobox is good to select the device .. but it has no way to be populate manually, hence,
why not add a "tool button" beside the combo-box, to open a file-dialogue
se the user can choose a device manually and when click on ok it will update the combo-box with the device address ?
what do you think about ?
thanks!
Massimo.
Il giorno 23/set/2010, alle ore 16.13, John C. Tull ha scritto:
> Hi Massimo,
> This is a known issue on OS X, but has received little attention to date. Other than manually setting up the path as you have done, I know of no other solution.
> https://trac.osgeo.org/qgis/ticket/1170
> Cheers,
> John
> On Sep 23, 2010, at 5:25 AM, Massimo Di Stefano wrote:
>> Hi :-)
>> i'm tring to use my bluethout gps device with Qgis, but it is no recognized
>> (there is no way in Qgis to manually add the path to device) ..
>> To fix i need to add manually "/dev/tty.GarminGPS10-Gps10" in : qgsgpsinformationwidgetbase.ui
>> (i added my device in the .ui file using "add item" in the combo box widget)
>> The weirs is .. after build qgis with the changes in " qgsgpsinformationwidgetbase.ui "
>> i have no new entry in the combobox, it is empty
>> but just "select the first entry (position 1 in the combobox, where i added the item in the .ui file)
>> it is empty ... (no device visible) but i'm able to connect to the device.
>> Is inside qgis a place where i can "statically" set the path to my gps device ?
>> Like a dialog to set manually the device address ?
>> (instead or in addition to choose it from the combobox, beacouse autodetect device doesn't works as aspected)
>> thanks for any hints!
>> Best regards,
>> Massimo_______________________________________________
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
