[Qgis-developer] Google Layers proxy
Ivan Mincik ivan.mincik at gista.sk
Sun Sep 26 11:09:47 EDT 2010
  On 09/25/2010 01:41 AM, MaurĂ­cio de Paulo wrote:
> ---------- Forwarded message ----------
> From: MaurĂ­cio de Paulo<mauricio.dev at gmail.com>
> Date: 2010/9/24
> Subject: Re: [Qgis-user] Google Layers proxy
> To: Ivan Mincik<ivan.mincik at gmail.com>
> Ivan, reading some urllib2 I've implemented a simple aproach.
> It's really buggy as I've inserted the code on the init() but it should
> prove that it is possible.
> I didn't test it yet as I'm not at work where there is a proxy.
Patch looks OK, but I have not any proxy to test either. I can't confirm
or falsify if it is working well.
> Actually it's harder to use qgis' proxy settings than to use the evironment
> settings.
> If I were to use environmental proxy settings then I would just need to
> change from urllib to urllib2 (probably the best option).
I have changed urllib to urllib2. Seems to work without any change. If
You can use 'environment settings' it can be easier way.
I will upload it to repository ASAP. Currently I have some problem to
connect to its web interface.
Ivan Mincik, Gista s.r.o.
