[Qgis-developer] setting size of mapcanvas / map via python in plugin
Richard Duivenvoorde rdmailings at duif.net
Mon Sep 27 09:01:29 EDT 2010
Hi Devs,
looking at: http://doc.qgis.org/stable/classQgsMapCanvas.html
is my conclusion ok that I cannot change the size of the mapcanvas from
within a python plugin / programmatically?
For the htmlimagemaplugin there is a feature request to be able to
determine the exact size of the output map image.
Another use-case is when I needed to have an image of a map in an exact
size to be used in some html/css page.
Till now I tried to resize the window in such a way combined with saving
the map as an image to determine the right size (pixelperfect :-) )
Am I missing something here (eg can I use the qt-parent of mapcanvast or
so?) or should I file a feature request?
Regards,
