[Qgis-developer] QgsMapCanvas - Special zoom
GOO Creations
goocreations at gmail.com
Thu Sep 30 15:13:45 EDT 2010
Hello,
Is there any trick I can use to zoom into a canvas with a specific
centre AND a specific scale.
I have 2 map canvases, and I want to zoom into the same position and
scale on both canvases at the same time: If i zoom into canvas1 at
location (x,y) with factor 0.87, canvas2 should also zoom in with
factor0.87 at position (x,y).
What I currently do is:
1. When the user zooms on one canvas (zoomLastStatusChanged signal), the
signal is caught and the continues to step 2
2. Zoomin -> QgsMapCanvas provides 2 functions that can be used:
zoomWithCenter and zoomScale
The problem is that there is not a function that can zoom into a certain
point WITH a certain scale.
If zoomScale is used and one image is moved/paned individual, the
zooming will have the same scale, but with different locations.
Hence if I zoom into one point, both canvases should the same location
(zoomed in with the same amount)
If zoomWithCenter is used a fixed factor will be used to zoom in. Hence,
if I zoom in on canvas1 with a factor different to 1, canvas2 will be
zoomed into the correct location, but with a factor of 1 and not the
factor of canvas1.
Does anyone have a solution to this problem? And is it even possible?
Thanks
Christoph
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20100930/bbc959b1/attachment.html
