[Qgis-developer] Python plugin: how to set a symbol for a layer?
Giuseppe Sucameli
sucameli at faunalia.it
Fri Apr 1 07:15:36 EDT 2011
Hi Luca,
On Fri, Apr 1, 2011 at 9:14 AM, <luca_manganelli at comune.trento.it> wrote:
> I've searched across documentation and mailing list, but I didn't found a
> page explaining how to set a symbol.
create your style within QGis and save it as e.g. "point.qml" in your plugin
folder,
then load it using this snapshot:
import os.path
style_path = os.path.join( os.path.dirname(__file__), "point.qml" )
(errorMsg, result) = vectorLayer.loadNamedStyle( style_path )
So to change the style of the layer it consists just in a file replacing
without any change
in your code.
Cheers.
> For example:
> - point layer: I want to use a circle with width 0.5 and gray colour with
> black border;
> - line layer: width 1 and continous green line
> any hint?
> Thank you in advance.
> Qgis-developer mailing list
Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110401/5fe64c87/attachment.html
