Fwd: Re: [Qgis-developer] Please vote: Proposed extension to 1.7 release schedule
Andreas Neumann a.neumann at carto.net
Fri Apr 1 11:01:13 EDT 2011
 sending this to the list, as I accidentally sent it only to Jürgen.
 Andreas
 -------- Original Message --------
 Subject: Re: [Qgis-developer] Please vote: Proposed extension to 1.7
 release schedule
 Date: Fri, 01 Apr 2011 16:24:24 +0200
 To: Jürgen E. Fischer <jef at norbit.de>
 Not necessarily, but it would have the following advantages:
 * the users would not have to manually get those three separate
 libraries
 * the libraries would be stripped down to the necessary (e.g. OL can be
 half the size of the regular full version), same for ExtJS and GeoExt
 * the libraries in our svn would be tested to work with each other.
 When one of the three libraries changes to a new version we would check
 them for compatibility and only replace them in our repository if they
 work. It happened in the past, that a newer SVN trunk version of OL
 would break some functionality.
 On the other hand it is the question whether we are allowed to keep
 separate versions in our SVN? Would the licenses of OL, GeoExt and
 Ext/Sencha allow that?
 Andreas
 On Fri, 1 Apr 2011 16:00:11 +0200, Jürgen E. Fischer wrote:
> Hi Andreas,
> On Fri, 01. Apr 2011 at 15:45:04 +0200, Andreas Neumann wrote:
>> I would propose to place it next to the documentation:
>> https://svn.osgeo.org/qgis/trunk/webclient
>> Currently the webclient is 3.7MB, about 600 files, but most of it is
>> just OpenLayers, Ext and GeoExt. I can strip it more down to the
>> necessary resources (maybe down to 2mb, 150 files). The libraries
>> (OL,
>> Ext, GeoExt) contain both deployment and debug versions.
> Do we also need the libraries in SVN?
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel.
> +49-4931-918175-20
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax.
> +49-4931-918175-50
> Software Engineer         D-26506 Norden
> http://www.norbit.de
 Andreas Neumann
 Böschacherstrasse 10A
 8624 Grüt (Gossau ZH)
 Switzerland
 Andreas Neumann
 Switzerland
