[Qgis-developer] Re: [Qgis-user] Multitemporal Multivariate data
visualization plugin
Marco Bernasocchi
marco at bernawebdesign.ch
Thu Apr 7 08:33:48 EDT 2011
Hi Alister,
I just released a new version of multi view that just disables one
visualisation if you dont have the required libs. it's a quick and dirty
thingy but i've no time until beginning of may...
hope it helps
cia Marco
On 04/07/2011 05:23 AM, Alister Hood wrote:
>> hi All, If you deal with multivariate, multitemporal and cyclic raster
>> data you might find interesting my multiview plugin [1]
>> and here [2] a screenshot of what can be done in terms of different
>> visualizations the code still has some minor glitches but it is very
>> well usable (and stable). As well here [3] there is an improved
> version
>> of scattergramm plugin that allows you to select points (or clusters
> on
>> the scattergramm and have them plotted on your map canvas (it's the
>> screenshot as well) I didn't publish this last (scattergramidentify)
>> plugin because I hope to get in contact with G. Picard (author of the
>> original scattergramm) and maybe merge the codebase. but in the
> meantime
>> you might still want to try it out :)
>> ciao
>> Marco
> Hi Marco,
> Someone has probably already told you - unfortunately the Multitemporal
> and Multivariate plugin won't currently work on Windows, as it requires
> the fractions module, which was introduced in Python 2.6. On Windows at
> least the OSGeo builds still use Python 2.5 :(
> Regards,
> Alister
> Qgis-user mailing list
Marco Bernasocchi
www.bernawebdesign.ch
skype: mbernasocchi
