[Qgis-developer] RuleBase - symbol levels don't persistent
Andrea Peri
aperi2007 at gmail.com
Sun Apr 10 17:46:58 EDT 2011
Using the qgis 1.7 r15690
If I try to set render using
Rule Base and symbol level.
It seem not saved when close the Layer-Properties windows.
I open the windows properties and rule-base windows I add some rules and
open the Symbol-levels.
It is firstly disables so I check to set enable and set some level.
After I click ok - ok and close the propeties-windows.
But if I re-open the again I notice the symbol-level is disable again.
I'm not sure if this is a bug or a missing functionality.
Andrea Peri
qwerty àèìòù
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110410/05e9a74b/attachment.html
