AW: [Qgis-developer] QGIS webclient into svn
Ivan Mincik
ivan.mincik at gista.sk
Thu Apr 14 05:46:27 EDT 2011
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
> authentication: maybe also as a plugin? I don't know. I don't have
> immediate plans. We should not forget that the primary goal is a
> out-of-the-box, easy to install, webgis solution.
I think, easy to install and out-of-the-box "run and display map on web"
is that what is needed in this case. You can always move to some bigger
webGIS solution if advanced stuff is needed.
> Not sure how I would implement authentication. It is probably totally
> dependent on the database used and the organization's need. It is
> probably necessary as soon as one starts to allow online digitizing.
> Any thoughts on how you would implement authentication?
You can implement Apache basic server authentication (using company's
LDAP for example) without any modification to webGIS app code.
Ivan Mincik, Gista s.r.o.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk2mwnMACgkQVqso/9cUsCzWuACfX1vCnl+dVC2CNwiZz7J1KrZ2
b40AoM5aqtt2DXjzFLBD94froticTQW9
=7xO4
-----END PGP SIGNATURE-----
