[Qgis-developer] problem with raster
Radim Blazek
radim.blazek at gmail.com
Mon Apr 18 13:20:03 EDT 2011
There is one problem, which I don't know how to solve. For certain
projections and source extent, reprojected extent of a map (both
raster and vector) may run to infinity. We are usually expecting some
reasonable values, with infinite or very large numbers everything
fails.
How should be handled this situation? Is it possible to find somehow
maximum reasonable area for given projection? It is probably possible
to tests if projection transformation works/fails on regular grid of
points in longlat. Is there a better solution?
Radim
On Mon, Apr 18, 2011 at 12:56 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> Hi everybody, I'm testing raster reprojection and I found a problem,
> maybe a bug.
> I try to reproject from epsg:4326 to epsg:32661 a raster of all world
> but qgis crash, here the lines before the problem
> Debug: QGIS(16362)/ KSycocaPrivate::openDatabase: Trying to open
> ksycoca from "/var/tmp/kdecache-lucadelu/ksycoca4"
> Debug: kfilemodule(16362)/kdecore (services)
> KMimeTypeFactory::parseMagic: Now parsing "/usr/share/mime/magic"
> "/home/luca/.local/share/mime/magic"
> /usr/local/share/qgis/python/plugins/osm/OsmFeatureDW.py:185:
> DeprecationWarning: QgsMapRenderer.destinationSrs() is deprecated
> self.coordXform = QgsCoordinateTransform(renderer.destinationSrs(),
> QgsCoordinateReferenceSystem(4326))
> qgis: /home/luca/compilati/qgis_svn/src/core/qgsrasterprojector.cpp:316:
> void QgsRasterProjector::preciseSrcRowCol(int, int, int*, int*):
> Assertion `*theSrcCol < mSrcCols' failed.
> Aborted
> thanks
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
> Qgis-developer mailing list
