[Qgis-developer] Failing Debian Squeeze daily build
Ivan Mincik
ivan.mincik at gista.sk
Wed Apr 20 02:33:48 EDT 2011
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
my daily Debian build failed on:
[ 64%] Generating moc_qgswmsprovider.cxx
cd "/tmp/buildd/qgis-1.7.0~trunk1/debian/build/src/providers/wms" &&
/usr/bin/moc-qt4 -I/usr/include/qt4 -I/usr/include/qt4/QtSvg
- -I/usr/include/qt4/QtWebKit -I/usr/include/qt4/QtGui
- -I/usr/include/qt4/QtTest -I/usr/include/qt4/QtXml
- -I/usr/include/qt4/QtSql -I/usr/include/qt4/QtNetwork
- -I/usr/include/qt4/QtCore -I/tmp/buildd/qgis-1.7.0~trunk1/debian/build
- -DQT_SVG_LIB -DQT_WEBKIT_LIB -DQT_GUI_LIB -DQT_TEST_LIB -DQT_XML_LIB
- -DQT_SQL_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_NO_CAST_TO_ASCII
- -DQGISDEBUG=1 -o
/tmp/buildd/qgis-1.7.0~trunk1/debian/build/src/providers/wms/moc_qgswmsprovider.cxx
/tmp/buildd/qgis-1.7.0~trunk1/src/providers/wms/qgswmsprovider.h
cd "/tmp/buildd/qgis-1.7.0~trunk1/debian/build" && /usr/bin/cmake -E
cmake_depends "Unix Makefiles" "/tmp/buildd/qgis-1.7.0~trunk1"
"/tmp/buildd/qgis-1.7.0~trunk1/src/providers/wms"
"/tmp/buildd/qgis-1.7.0~trunk1/debian/build/src/providers/wms/CMakeFiles/wmsprovider.dir/DependInfo.cmake"
- --color=
Dependee
is newer than depender
"/tmp/buildd/qgis-1.7.0~trunk1/debian/build/src/providers/wms/CMakeFiles/wmsprovider.dir/depend.internal".
Dependee
"/tmp/buildd/qgis-1.7.0~trunk1/debian/build/src/providers/wms/CMakeFiles/CMakeDirectoryInformation.cmake"
Scanning dependencies of target wmsprovider
make[3]: Leaving directory `/tmp/buildd/qgis-1.7.0~trunk1/debian/build'
/usr/bin/make -f src/providers/wms/CMakeFiles/wmsprovider.dir/build.make
make[3]: Entering directory `/tmp/buildd/qgis-1.7.0~trunk1/debian/build'
/usr/bin/cmake -E cmake_progress_report
"/tmp/buildd/qgis-1.7.0~trunk1/debian/build/CMakeFiles"
[ 64%] Building CXX object
src/providers/wms/CMakeFiles/wmsprovider.dir/qgswmsprovider.cpp.o
/usr/bin/c++ -Dwmsprovider_EXPORTS -DQT_SVG_LIB -DQT_WEBKIT_LIB
- -DQT_GUI_LIB -DQT_TEST_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_NETWORK_LIB
- -DQT_CORE_LIB -DQT_NO_CAST_TO_ASCII -DQGISDEBUG=1 -DQT_DEBUG -g -O2 -g
- -fPIC -I/usr/include/qt4 -I/usr/include/qt4/QtSvg
- -I/usr/include/qt4/QtCore -I"/tmp/buildd/qgis-1.7.0~trunk1/debian/build"
- -I"/tmp/buildd/qgis-1.7.0~trunk1/src/providers/wms/."
- -I"/tmp/buildd/qgis-1.7.0~trunk1/src/providers/wms/../../core"
- -I"/tmp/buildd/qgis-1.7.0~trunk1/src/providers/wms/../../core/raster"
- -Wall -Wno-long-long -Wformat-security -Wno-strict-aliasing
- -DCORE_EXPORT= -DGUI_EXPORT= -DPYTHON_EXPORT= -DANALYSIS_EXPORT= -o
CMakeFiles/wmsprovider.dir/qgswmsprovider.cpp.o -c
"/tmp/buildd/qgis-1.7.0~trunk1/src/providers/wms/qgswmsprovider.cpp"
/tmp/buildd/qgis-1.7.0~trunk1/src/providers/wms/qgswmsprovider.cpp: In
member function 'void QgsWmsProvider::tileReplyFinished()':
/tmp/buildd/qgis-1.7.0~trunk1/src/providers/wms/qgswmsprovider.cpp:729:
error: 'class QNetworkReply' has no member named 'rawHeaderPairs'
error: template argument 1 is invalid
error: invalid type in declaration before '(' token
error: request for member 'brk' in '_container_', which is of non-class
type 'int'
error: request for member 'i' in '_container_', which is of non-class
type 'int'
error: request for member 'e' in '_container_', which is of non-class
type 'int'
type 'int'
type 'int'
error: expected initializer before '&' token
type 'int'
/tmp/buildd/qgis-1.7.0~trunk1/src/providers/wms/qgswmsprovider.cpp:731:
error: 'pair' was not declared in this scope
make[3]: ***
[src/providers/wms/CMakeFiles/wmsprovider.dir/qgswmsprovider.cpp.o] Error 1
make[2]: *** [src/providers/wms/CMakeFiles/wmsprovider.dir/all] Error 2
make[2]: Leaving directory `/tmp/buildd/qgis-1.7.0~trunk1/debian/build'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/tmp/buildd/qgis-1.7.0~trunk1/debian/build'
make: *** [build-stamp] Error 2
dpkg-buildpackage: error: debian/rules build gave error exit status 2
E: Failed autobuilding of package
W: no hooks of type C found -- ignoring
I: unmounting /var/cache/pbuilder/ccache filesystem
I: unmounting dev/pts filesystem
I: unmounting proc filesystem
I: cleaning the build env
I: removing directory /var/cache/pbuilder/build//27998 and its
subdirectories
Thanks
Ivan Mincik, Gista s.r.o.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAk2ufksACgkQVqso/9cUsCxOHwCaAlJ0m46OeRLDw06veFOmWnJU
3QYAoK44EV+x1ZS1nTrm7BWbhEdz6Bm4
=pqBc
-----END PGP SIGNATURE-----
