[Qgis-developer] ecw and linux nightly builds
Jürgen E. Fischer
jef at norbit.de
Wed Apr 20 03:28:14 EDT 2011
Hi Ramon,
On Wed, 20. Apr 2011 at 15:20:12 +0800, custard wrote:
> I have previously complied the ecw library (when using ubuntugis-unstable)
> and GDAL knows about ecw, but QGIS doesn't seem to want to talk to it.
Probably not the version that QGIS uses. The nightly builds are done against
the "normal" version of the distribution. You probably only have ecw support
for a version from a "foreign" repository.
If you add ecw support to the distribution's version, QGIS should also use it.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
