[Qgis-developer] pyQT combo box & QGIS plug-in signal
argumentquestion
karsten vennemann
karsten at terragis.net
Fri Apr 22 17:45:13 EDT 2011
Maybe I shoud clarify this more
Right now this works: I can send the signal and have the value of the combox be used to update a field in the attribute table ,
however in addition I would like to add the id of the combobox that I can determine which column should be updated in the changeValue function
How can this be done ?
Karsten
> -----Original Message-----
> From: qgis-developer-bounces at lists.osgeo.org
> [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of
> karsten vennemann
> Sent: Friday, April 22, 2011 14:32
> To: qgis-developer at lists.osgeo.org
> Subject: [Qgis-developer] pyQT combo box & QGIS plug-in
> signal argumentquestion
> Hi all,
> in a python QGIS plug-in I have a form with a dynamically
> generated pyQT combo box.
> Now I am trying to have a change in the combo box send a
> signal with one argument (which is the id of combo box) to
> the called function changeValue. Note this changes the
> attribute of one field in a shape file attribute table and I
> need the combo box id to know which field will be changed by
> the changeValue function). How can I do this ?
> So far I have.
> QObject.connect(comboBoxNew[dropbox_counter],SIGNAL("currentIn
> dexChanged(QString)"),self.changeValue)
> def changeValue(self, value):
> mc = self.canvas
> layer = mc.currentLayer()
> ob = layer.selectedFeaturesIds()
> layer.changeAttributeValue(int(ob[0]),self.id(),value)
> Thanks for any hints as I have been stuck with this for days ;)
> Cheers
> Karsten Vennemann
