[Qgis-developer] PostGIS connections: take them from PgAdmin3?
Paolo Cavallini cavallini at faunalia.it
Sat Apr 23 03:28:11 EDT 2011
Alessandro, Mayeul: could you please add your notes to
https://trac.osgeo.org/qgis/ticket/3769 ?
Thanks.
Il giorno ven, 22/04/2011 alle 23.37 +0200, a.furieri at lqt.it ha
scritto:
> On Fri, 22 Apr 2011 22:10:29 +0200, Mayeul Kauffmann wrote
> > - This relies on knowing where this pgadmin config file is. I guess
> > it is in ~/pgadmin3 in most GNU/Linux box. Is the pgadmin config
> > file stored in a predictable place in Windows?
> Hi Mayeul,
> WinOz doesn't uses any file to store permanent
> settings: it uses the System Registry instead.
> so pgadmin connections are stored under the
> following registry key:
> HKEY_CURRENT_USER/Software/pgAdmin III/Servers
Paolo Cavallini: http://www.faunalia.it/pc
