[Qgis-developer] cppcheck report
Gabriele Monfardini
gabrimonfa at gmail.com
Fri Apr 29 09:08:06 EDT 2011
Hi all,
I've runned cppcheck on source code revision 15849.
This is the report.
[./app/qgsmaptooladdvertex.cpp:111]: (error) Dangerous iterator usage.
After erase the iterator is invalid so dereferencing it or comparing
it with another iterator is invalid.
[./app/qgssinglesymboldialog.cpp:149]: (error) Possible null pointer
dereference: mVectorLayer - otherwise it is redundant to check if
mVectorLayer is null at line 223
[./core/pal/problem.cpp:2461]: (error) Memory leak: solution
[./core/qgsgeometry.cpp:1565]: (error) Mismatching allocation and
deallocation: newbuffer
[./core/qgsgeometry.cpp:1621]: (error) Mismatching allocation and
[./core/qgsgeometry.cpp:1679]: (error) Mismatching allocation and
[./core/qgsgeometry.cpp:1757]: (error) Mismatching allocation and
[./core/qgsgeometry.cpp:1879]: (error) Mismatching allocation and
[./core/qgsgeometry.cpp:2129]: (error) Mismatching allocation and
[./core/qgsgeometry.cpp:4802]: (error) Mismatching allocation and
deallocation: newGeometry
[./core/spatialite/spatialite.c:124214]: (error) Memory leak: p
[./core/spatialite/spatialite.c:169967]: (error) Memory leak: p
[./core/spatialite/spatialite.c:170206]: (error) Memory leak: p
[./core/spatialite/sqlite3.c:14405]: (error) Common realloc mistake:
"p" nulled but not freed upon failure
[./mapserver/qgssldparser.cpp:1408]: (error) Mismatching allocation
and deallocation: adfFixedLevels
[./plugins/dxf2shp_converter/shapelib-1.2.10/dbfopen.c:540]: (error)
Memory leak: pszFullname
[./plugins/dxf2shp_converter/shapelib-1.2.10/shpopen.c:458]: (error)
Memory leak: pabyBuf
[./plugins/dxf2shp_converter/shapelib-1.2.10/shpopen.c:657]: (error)
Memory leak: pszBasename
[./plugins/dxf2shp_converter/shapelib-1.2.10/shpopen.c:662]: (error)
Resource leak: fpSHP
[./providers/grass/qgsgrassprovider.cpp:407]: (error) Common realloc
mistake: "wkb" nulled but not freed upon failure
Regards,
Gabriele Monfardini
