[Qgis-developer] Spatialite views not working in QGIS
a.furieri at lqt.it
a.furieri at lqt.it
Fri Apr 29 10:21:32 EDT 2011
On Fri, 29 Apr 2011 15:32:05 +0200, Stefan Keller wrote
> > c) accordingly to all this, SpatiaLite defines any
> > Spatial VIEW on VIEWS_GEOMETRY_COLUMNS (not on
> > GEOMETRY_COLUMNS): and this allows to fully support
> > Spatial Index for VIEWs as well
> Cool! So, what can I do?
> Just replace this statement:
> << INSERT INTO GEOMETRY_COLUMNS VALUES ('Towns_v1', 'Geometry',
> 'POINT', 2, 32632, 0);
> to this?
> >> INSERT INTO VIEWS_GEOMETRY_COLUMNS VALUES ('Towns_v1', 'Geometry',
Hi Stefan,
just a simple practical example:
CREATE TABLE a_test (
code INTEGER PRIMARY KEY,
category TEXT);
CREATE TABLE b_test (
id INTEGER PRIMARY KEY,
code INTEGER,
name TEXT);
SELECT AddGeometryColumn(
'b_test', 'geom', 4326, 'POINT', 'XY');
CREATE VIEW vw_test AS
SELECT b.id AS pk_id, b.code AS code,
a.category AS category,
b.name AS name, b.geom AS the_geom
FROM b_test AS b
JOIN a_test AS a ON (a.code = b.code);
INSERT INTO views_geometry_columns
(view_name, view_geometry, view_rowid,
f_table_name, f_geometry_column)
VALUES ('vw_test', 'the_geom', 'pk_id',
'b_test', 'geom');
bye Sandro
