[Qgis-developer] local installation of qgis trunk without GRASS
plugin
Otto Dassau
dassau at gbd-consult.de
Sat Apr 30 06:28:11 EDT 2011
Am Sat, 30 Apr 2011 12:01:10 +0200
schrieb Jürgen E. Fischer <jef at norbit.de>:
> On Sat, 30. Apr 2011 at 11:52:15 +0200, Otto Dassau wrote:
> > Hi,
> > when I compile qgis trunk and install it in a local folder
> > (e.g. /software/qgis_trunk) all is fine except for the GRASS plugin. The
> > libraries are build, but it is not selectable in the Plugin Manager.
> > Does anybody know where the problem is?
> It probably doesn't find the grass shared libraries. Did you add
> /opt/grass/lib to /etc/ld.so.conf or LD_LIBRARY_PATH?
yes, it is written here in /etc/ld.so.conf.d/grass-6.4.1.conf
/opt/grass/lib
which is linked to /etc/ld.so.conf
Otto
