[Qgis-developer] Re: Plans for the 1.7 Release
Tim Sutton
lists at linfiniti.com
Sat Apr 30 18:51:46 EDT 2011
Hi All
Any more thoughts on this? I am about to delete the 'old' svn clone of
qgis on github and replace it with a pruned copy that has all branches
etc and is current to tonight. Personally I dont have a strong opinion
- I'd be happy to just run with github for now and we can always make
an 'official' repo on qgis.org later if needed.
Regards
Tim
On Thu, Apr 28, 2011 at 2:39 PM, Pirmin Kalberer <pi_ml at sourcepole.com> wrote:
> Hi all,
> Am Donnerstag, 28. April 2011, um 13.40:46 schrieb Tim Sutton:
>> I just wanted to add following an offlist conversation with Juergen
>> that self hosting the git repository on qgis.org is also an option and
>> then cloning it over to github. Feel free to discuss if you have a
>> preferred way of doing things.
> Self-hosting has some advantages but needs quite some work done. I think, http
> (and https?) transport would be a must. I recently looked at http read-only
> support with Apache, but this would require a dist-upgrade of the machine. The
> current git infrastructure on qgis.org is not made for large-scale use (it was
> a side-project of the Redmine installation). Maybe the KDE infrastructure
> (http://community.kde.org/Sysadmin/GitKdeOrgManual) would be more appropriate.
> If somebody is willing to improve and maintain the git infrastructure, than it
> is certainly an option.
> I prefer github as the main repository for QGIS. The "fork me" functionality
> gives a great new way for contributions of people outside of the core team.
> Everybody can start a public topic branch and send pull requests. Currently, I
> would neither use the issue tracker nor the Wiki of github - but the
> repository viewer is great.
> Regards
> Pirmin
>> On Thu, Apr 28, 2011 at 9:23 AM, Tim Sutton <lists at linfiniti.com> wrote:
>> > Hi All
>> > I just wanted to recap a little for those who were not present at the
>> > hackfest our plans for the roll out of 1.7. This release will be a
>> > little more involved since we are going to simultaneously migrate to
>> > GIT and Redmine. Here is a little synopsis of what is going to be
>> > happening:
>> > Branching 1.7
>> > - Translation period will come to an end on friday evening (29 April)
>> > after which we will create the release branch for 1.7 (actual
>> > branching will happen sometime on the 30th).
>> > - 1.7 will be the last public release of the 1.x series.
>> > - If developer effort supports it we will make 1.7.x bug fix releases
>> > in the interim until the 2.0 release
>> > - 1.9.x releases will be made but not widely announced and will break
>> > api compatibility and deprecate various features
>> > - 1.9.x and possible maintenance of 1.7.x releases will be done from GIT
>> > Svn -> Git Migration
>> > - Migration will take place immediately after branching for 1.7
>> > release but before call for packaging and release announcements
>> > - We will revoke svn write access for all committers
>> > - We will git svn clone qgis into a git repository
>> > - We will prune out the various sub projects so that the QGIS git
>> > repository represents only the QGIS code base itself and not code
>> > examples and other things found under trunk.
>> > - We will create additional repositories for each of the other
>> > subdirectories in trunk.
>> > - We will push the clones into github.org/qgis which will then become
>> > the official repo
>> > - We will reinstate commit access for svn committers but to the git
>> > repo now instead.
>> > Trac -> Redmine Migration
>> > - We will ask OSGEO for a backup of our current trac instance,
>> > including uploaded resources etc.
>> > - We will redeploy that backup on qgis.org
>> > - We will install the trac git plugin
>> > - We will migrate the svn commit references to git commit hash references
>> > - We will run the trac -> redmine migration scripts to migrate the
>> > tickets - We will ask osgeo to make the old trac instance read only and
>> > put a redirector in place pointing to our redmine instance.
>> > Release
>> > - We will include in the release announcements a notice about the
>> > GIT/Redmine migration, with pointers to required urls, documentation
>> > etc.
>> > - We will issue a call for packaging against the release branch in git
>> > so that packaging related changes can be committed there directly
>> > Rollback Option
>> > Naturally making such a large change to our infrastructure involves
>> > some risk. For this reason, existing svn and trac infrastructure will
>> > not be removed for some time and will be simply made readonly at the
>> > time of switch over. If we encounter any major issues during the
>> > changeover process we will remove the readonly status of svn & trac,
>> > evaluate the issues and come up with solutions, and then repeat the
>> > process at a later date. Obviously this will be disruptive too and we
>> > will make our best effort to avoid such actions being required.
>> > Help & Discussion
>> > The decision to do the migration has already been take at the
>> > hackfest, but if anyone has implementation specific ideas or concerns
>> > lets hear them. Also if you are a GIT ninja or a Redmine black belt,
>> > and would like to make the migration happen smoothly, please let me
>> > know as I will appreciate any helping hands.
>> > Regards
>> > Tim
>> > Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
>> > Please do not email me off-list with technical
>> > support questions. Using the lists will gain
>> > more exposure for your issues and the knowledge
>> > surrounding your issue will be shared with all.
>> > Visit http://linfiniti.com to find out about:
>> > * QGIS programming and support services
>> > * Mapserver and PostGIS based hosting plans
>> > * FOSS Consulting Services
>> > Skype: timlinux
>> > Irc: timlinux on #qgis at freenode.net
> Pirmin Kalberer
> Sourcepole - Linux & Open Source Solutions
> http://www.sourcepole.com
Skype: timlinux
