[Qgis-developer] Breaking API and merge of threading branch
Martin Dobias
wonder.sk at gmail.com
Thu Aug 11 03:49:40 EDT 2011
On Wed, Aug 10, 2011 at 10:13 PM, Charlie Sharpsteen
<chuck at sharpsteen.net> wrote:
> On Wed, Aug 10, 2011 at 3:32 AM, Tim Sutton <lists at linfiniti.com> wrote:
>> I think the fact that we are going to break API in 2.0 is well known
>> and discussed often in releases, blogs, qgis hackfests etc. and is a
>> general expectation when performing a major version numbering change.
>> I think your approach is good (tag last api compatibility etc). As far
>> as I am concerned we can go ahead with API breakage today. There are a
>> number of other gut wrenching changes I would like to make for 2.0:
>> - change theme to 'gis' theme by default
>> - get rid of kids theme
>> - rename default theme to 'legacy'
>> - remove all deprecated api calls
>> Many parts of our api have developed inconsistencies and I would like
>> to spend some time putting my 'rpl' binary to good use trying to clean
>> these up before we release. I think we should continue the practice of
>> marking new api additions / changes with a @note added in 2.0 or
>> @note replaces getLayerId in 2.0 etc. as far as possible so that
>> people can adapt to our changes easily.
>> Anyway +1 for API breakage from me - we will continue maintaining
>> 1.7.x for now anyway for those looking for stability. The number of
>> things we can reasonable backport will shrink as we mess with the API
>> but I don't see the impact to be too big.
>> Regards
>> Tim
> Since backwards-incompatible changes are being discussed, may I also suggest
> that we update PyQGIS to use version 2 of the SIP apis for QString and
> QVariant?
> The version 2 API is much more Pythonic and has better support for Unicode
> and Python 3. It is also the only version that is compatible with PySide.
> Because of this, many GUI components that use the Enthought scientific
> python modules are only compatible with version 2 of the SIP APIs. Notable
> projects include Matplotlib and IPython.
Yes, I would like to do this change during the development of 2.0.
Another python related change in my todo list is to move plugin
metadata out of __init__.py file to a text file.
Martin
