[Qgis-developer] building debs: dependency on osgearth to be added?
Pirmin Kalberer pi_ml at sourcepole.com
Fri Aug 12 15:59:34 EDT 2011
Hi Paolo,
Am Freitag, 12. August 2011, 16.45:09 schrieb Paolo Cavallini:
> Hi all.
> Now the osgearth plugin builds and is packaged. However, if libosgearth-dev
> is not installed, packaging ends with an error. I think the dependency
> should be added. All the best.
libosgearth-dev is already a build dependency. Did you run "sudo apt-get
build-dep qgis"?
Pirmin
Pirmin Kalberer
Sourcepole  -  Linux & Open Source Solutions
http://www.sourcepole.com
