AW: Re: AW: [Qgis-developer] dimensioning plugin: spurious lines?
Ziegler Stefan Stefan.Ziegler at bd.so.ch
Tue Aug 16 10:02:33 EDT 2011
.qgis/python/plugins/dimensioning/sqlite/
There are several sqlite databases. Looking at the size of them I guess
that the active one (dimension.sqlite) is not empty. Try to copy
dimension.sqlite.template to dimension.sqlite.
> -----Ursprüngliche Nachricht-----
> Von: Paolo Cavallini [mailto:cavallini at faunalia.it]
> Gesendet am: Dienstag, 16. August 2011 15:58
> An: Ziegler Stefan
> Cc: qgis-developer
> Betreff: Re: AW: [Qgis-developer] dimensioning plugin: spurious lines?
> Il 16/08/2011 15:51, Ziegler Stefan ha scritto:
> > is the spatialite database empty at the beginning? Did it
> work properly before? Or do
> > you use it the first time?
> Oh, I see: where do I find the db?
> Paolo Cavallini: http://www.faunalia.it/pc
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110816/3e5cee21/attachment.html
