[Qgis-developer] least surprise, or: which terms should be used?
Paolo Cavallini
cavallini at faunalia.it
Fri Aug 19 03:38:23 EDT 2011
Il 19/08/2011 09:21, Ramon Andinach ha scritto:
> I think Werner's point is valid, ie. if you're using the SAGA modules, then presumably you know what is meant in SAGA by "grid".
> But,
> If you were going to select one, then please use raster.
> In my work situation, I find myself having to clarify what sort of thing I mean by grid far to frequently to want to introduce a another one.
The plugin is meant to add SAGA functions to QGIS, so our main target should be QGIS
users, not SAGA ones, I guess. However, life shouldn't be too difficult for anyone.
Thanks.
Paolo Cavallini: http://www.faunalia.it/pc
