[Qgis-developer] QgsExpression: replacement for QgsSearchString
Nathan Woodrow
madmanwoo at gmail.com
Sun Aug 21 07:56:32 EDT 2011
Looking good Martin. No objections from me. The old QgsSearchString was a
bit string in the way it handled a few things so I'm glad it's been
simplified in your chances.
I'm just merging with my expression labeling branch, which used
QgsSearchString at the moment. I will report if I find any bugs.
- Nathan
On Sat, Aug 20, 2011 at 6:51 AM, Martin Dobias <wonder.sk at gmail.com> wrote:
> Hi everyone
> recently I have been trying to fix some flaws in search string
> implementation and it turned out that rather than fixing them
> one-by-one it will be easier to rewrite that code completely. Search
> string and associated searching in attribute table was one of my first
> contributions to QGIS and my first attempt to write a parser and an
> evaluator. QgsExpression is my second attempt :-)
> The main reason for the redesign was to bring the evaluation closer to
> SQL semantics and to clean the code which started to be hard to
> maintain.
> QgsExpression is meant to be a replacement for QgsSearchString class.
> Most of the changes are under the hood:
> - fixed and simplifed the parser grammar and tree creation
> - simplified lexer
> - only one evaluation routine (instead of separate getValue/checkAgainst)
> - correct handling of NULL values and three-value logic from SQL
> (true, false, unknown)
> - fixed error reporting
> - easily extensible list of functions, saner evaluation of expressions
> - using QVariant for return values instead of a special type
> - slightly faster evaluation
> - a more suitable class name
> - tests included (!!!) :-)
> Only few changes are visible for users:
> - spaces were removed from "to int", "to real" and "to string"
> functions because function names must not contain spaces
> - null values are handled correctly by the functions and operators
> - errors are reported when conversions between types fail
> Btw. type conversions (currently supporting null, int, double, string)
> are implemented in many different ways in databases. I have done some
> tests on sqlite3, postgresql and mysql and many times there was no
> consensus what the outcome of an evaluation should be:
> - 7 > '6x' :: mysql=1, sqlite=0, postgresql=error
> - 7 > '6' :: mysql=1, sqlite=0 (!), postgresql=1
> - '6x' :: mysql=6 (+warning), sqlite=6, postgresql=error
> - '3'+'5' :: mysql=8, sqlite=8, postgresql=error
> - 3/5 :: mysql=0.6, sqlite=0, postgresql=0
> - length(123) :: mysql=3, sqlite=3, postgresql=error
> - 0 or 1 :: mysql=1, sqlite=1, postgresql=error
> - 0 or 'x' :: mysql=0 (+warning), sqlite=0, postgresql=error
> PostgreSQL is very strict about type conversions, Sqlite is not strict
> at all and MySQL is somewhere in the middle. I have ended up with
> these conversion rules:
> - implicit conversions to desired types
> - string->number conversions with invalid input return error
> - arithmetic operators convert to numeric
> - comparison with numeric type => numeric comparison
> The code is here:
> https://github.com/wonder-sk/Quantum-GIS/tree/expr
> If there are no objections I will apply the changes to master in few
> days. Given that I have been simultaneously writing unit tests I am
> quite confident that there are not too many bugs (unit tests really
> help!). In that branch I have replaced all the occurrences of search
> string with expressions. So playing with search in attribute table or
> doing calculation in field calculator will use the new engine.
> Martin
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110821/c9a1c174/attachment.html
