[Qgis-developer] Release plans for 1.7.1
luca_manganelli at comune.trento.it luca_manganelli at comune.trento.it
Wed Aug 24 07:57:44 EDT 2011
qgis-developer-bounces at lists.osgeo.org scritti il 23/08/2011 21.19.36
> Hi All
> I would like to put out a maintenance release of the 1.7 branch at the
> end of this month. There won't be too much activity surrounding the
> release as the branch is in feature freeze. There may have been some
> small string changes so it would be good if the translators could give
> the branch a quick once over.
> I am behind a couple of weeks on checking the application of
> backportable code, but I will be going over the last few weeks of
> commits and backporting anything relevant to the release branch.
> If you have applied bug fixes to master, it would be great if you
> could help me to make sure they have also been applied to the release
> branch.
It would be nice to release 1.7.1 version with only bugfixes and no new
features.
I discovered that with QGIS 1.6-1.7 WMS connection never uses proxy
user/password authentication, this is a big problem in corporate
environments. I filed the bug #3844. The bug appeared after the rewrite of
QGIS connection management (see this: #3912 it was fixed, but now it is
broken again).
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110824/2a88deb5/attachment-0001.html
