[Qgis-developer] QgsExpression: replacement for QgsSearchString
Marco Hugentobler marco.hugentobler at sourcepole.ch
Sat Aug 27 05:47:26 EDT 2011
Hi Martin
> If there are no objections I will apply the changes to master in few
> days
No objections from me, the new class seems to work well.
Are you going to remove the search string classes when merging or do you plain
to wait until  the first other api break has happened?
Regards,
Marco
Am Freitag, 19. August 2011, 22.51:47 schrieb Martin Dobias:
> Hi everyone
> recently I have been trying to fix some flaws in search string
> implementation and it turned out that rather than fixing them
> one-by-one it will be easier to rewrite that code completely. Search
> string and associated searching in attribute table was one of my first
> contributions to QGIS and my first attempt to write a parser and an
> evaluator. QgsExpression is my second attempt :-)
> The main reason for the redesign was to bring the evaluation closer to
> SQL semantics and to clean the code which started to be hard to
> maintain.
> QgsExpression is meant to be a replacement for QgsSearchString class.
> Most of the changes are under the hood:
> - fixed and simplifed the parser grammar and tree creation
> - simplified lexer
> - only one evaluation routine (instead of separate getValue/checkAgainst)
> - correct handling of NULL values and three-value logic from SQL
> (true, false, unknown)
> - fixed error reporting
> - easily extensible list of functions, saner evaluation of expressions
> - using QVariant for return values instead of a special type
> - slightly faster evaluation
> - a more suitable class name
> - tests included (!!!) :-)
> Only few changes are visible for users:
> - spaces were removed from "to int", "to real" and "to string"
> functions because function names must not contain spaces
> - null values are handled correctly by the functions and operators
> - errors are reported when conversions between types fail
> Btw. type conversions (currently supporting null, int, double, string)
> are implemented in many different ways in databases. I have done some
> tests on sqlite3, postgresql and mysql and many times there was no
> consensus what the outcome of an evaluation should be:
> - 7 > '6x' :: mysql=1, sqlite=0, postgresql=error
> - 7 > '6' :: mysql=1, sqlite=0 (!), postgresql=1
> - '6x' :: mysql=6 (+warning), sqlite=6, postgresql=error
> - '3'+'5' :: mysql=8, sqlite=8, postgresql=error
> - 3/5 :: mysql=0.6, sqlite=0, postgresql=0
> - length(123) :: mysql=3, sqlite=3, postgresql=error
> - 0 or 1 :: mysql=1, sqlite=1, postgresql=error
> - 0 or 'x' :: mysql=0 (+warning), sqlite=0, postgresql=error
> PostgreSQL is very strict about type conversions, Sqlite is not strict
> at all and MySQL is somewhere in the middle. I have ended up with
> these conversion rules:
> - implicit conversions to desired types
> - string->number conversions with invalid input return error
> - arithmetic operators convert to numeric
> - comparison with numeric type => numeric comparison
> The code is here:
> https://github.com/wonder-sk/Quantum-GIS/tree/expr
> days. Given that I have been simultaneously writing unit tests I am
> quite confident that there are not too many bugs (unit tests really
> help!). In that branch I have replaced all the occurrences of search
> string with expressions. So playing with search in attribute table or
> doing calculation in field calculator will use the new engine.
> Martin
> Qgis-developer mailing list
