[Qgis-developer] Create vector layer directly in PostGIS
uk52rob
uk52rob at yahoo.co.uk
Wed Aug 31 06:13:34 EDT 2011
Giovanni,
Thanks, but this only seems to be able to load in shapefiles.
What I would like is to remove the need to store a shapefile in the first
instance.
Eg. Press the 'New Shapefile Layer' toolbar button, fill in the attributes,
then select a PostGIS DB to store to, not a shapefile.
Cheers
-----Original Message-----
From: Giovanni Manghi [mailto:giovanni.manghi at gmail.com]
Sent: 31 August 2011 10:55
To: uk52rob
Cc: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Create vector layer directly in PostGIS
> Has anyone seen a plug-in to create a new vector layer directly in a
> table,
Postgis Manager
