[Qgis-developer] Globe crashes QGIS
Giovanni Manghi
giovanni.manghi at gmail.com
Thu Dec 1 17:55:01 EST 2011
I tested also under Windows, it crashes too.
cheers
-- Giovanni --
On Thu, 2011-12-01 at 11:42 +0100, Paolo Cavallini wrote:
> See below.
> All the best.
> Warning: Object::connect: No such signal QgsGdalProvider::statusChanged(
> QString ) in
> /home/paolo/build/qgis/Quantum-GIS/src/core/raster/qgsrasterlayer.cpp:2445
> <class 'qgis.core.QgsRasterLayer'>
> Warning: Application asked to unregister timer 0x63000012 which is not
> registered in this thread. Fix application.
> Warning: Could not find plugin to read objects from file
> ".osgearth_engine_osgterrain".
> [osgEarth]* WARNING: Failed to load terrain engine driver for "osgterrain"
> [osgEarth]* FAILED to create a terrain engine for this map
> Errore di segmentazione (core dumped)
