[Qgis-developer] Heatmap Plugin
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Sat Dec 3 05:48:52 EST 2011
>Heatmaps would be great because currently, it's always necessary to
start GRASS to do something >like that.
>Can you write it in C++ to go into core?
>The input should be any point layer file. Output should be a raster
layer. A lot of usable code should >be contained in the interpolation
plugin which works in this way.
I can only second that. A convenient way to write a new interpolation
function is to derive a subclass from QgsInterpolator
(src/analysis/qgsinterpolator.h). Interpolation usually requires a lot
of computation, therefore it is good to implement it in the analysis
library in C++. Like that, the method is available to QGIS and its
plugins (also python) and other applications using QGIS libs.
Regards,
Marco
On 03.12.2011 10:48, Anita Graser wrote:
> Hi,
> On Sat, Dec 3, 2011 at 8:14 AM, aruntheguy at gmail.com
> <mailto:aruntheguy at gmail.com> <aruntheguy at gmail.com
> <mailto:aruntheguy at gmail.com>> wrote:
> Hello all,
> I was browsing through the plugin ideas to work on something, and
> this
> http://hub.qgis.org/wiki/quantum-gis/Python_Plugin_Ideas#heatmaps-reusable-python-code
> particular plugin idea seemed to be a good start.
> start GRASS to do something like that.
> Is anyone already working on it? Otherwise I will take it up.
> The page contains just the link. It would be great if more
> information is provided like, use scenario, what it is exactly
> supposed to do? The Input is of course a gpx file, with the
> available code, what should be produced as the output in Qgis? Any
> information regarding this is welcome.
> layer. A lot of usable code should be contained in the interpolation
> Looking forward to having this functionality in QGIS.
> Regards,
> Anita
> Regards
> Arunmozhi
> Twitter: @tecoholic
> Website: http://arunmozhi.in
> IRC Nick: teco
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
Dr. Marco Hugentobler
Sourcepole - Linux& Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111203/5a881a01/attachment.html
