[Qgis-developer] building qgis on centos
Volker Fröhlich volker27 at gmx.at
Tue Dec 6 10:53:09 EST 2011
Dear Santhosh,
I recommend to use the packages from ELGIS. If you need the trunk version of
QGIS, please consider to read the below anyway and probably follow the link on
rebuilding RPMs.
http://hub.qgis.org/projects/quantum-gis/wiki/download#RHEL-CentOS-Scientific-
Linux-
Volker
Am Dienstag, 6. Dezember 2011, 16:26:44 schrieb santhosh shirrali:
> hello
> iam trying to build qgis on centos 6 after installing all the dependency
> packages iam getting the following error in ccmake ..
>  CMake Error at CMakeLists.txt:192 (MESSAGE):
>    Some Qt4 modules haven't been found!
> Qt QTWEBKIT library not found.
> and after that i installed Qt webkit from the rpm source but iam getting
> the same mistake can any body give a solution how to solve this problem
> Regards
> Santhosh
