[Qgis-developer] (First?) API break
Andreas Neumann
a.neumann at carto.net
Sun Dec 11 12:52:49 EST 2011
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Thanks Anne,
This sounds like a plan.
Andreas
On 12/11/2011 06:12 PM, Anne Ghisla wrote:
> On Sun, 11 Dec 2011 15:26:55 +0100 Andreas Neumann
> <a.neumann at carto.net> wrote:
>> in javascript there is try and catch for such problems. Ore one
>> could test if an object/method/property is present. There are a
>> lot of browser differencies - so in a web environment it is quite
>> normal to test for capabilities.
>> How can one check if an object/method is present in Python?
> Hello Andreas, all,
> the check can be done during import:
> """ try: from qgis.core import newFunctionName as function except:
> from qgis.core import oldFunctionName as function """
> so that you can use "function" anywhere in the code without
> further checks. To keep the import code short, only the previous
> version of the API is tested. If a plugin developer wants to extend
> support to even older versions, I would recommend to create a
> separate "LTS" version. What do you think?
> Anne
> _______________________________________________ Qgis-developer
> mailing list Qgis-developer at lists.osgeo.org
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iQEcBAEBAgAGBQJO5O3tAAoJELiCsGDopvBCrAwH/2ydwarWM9Gl2fInHmtTb/ZA
NlFFLKnBozPljo4DM+vgV4Uluxx2FfygPSF1uf+7eBfUcBgZLXAW+3WaPLornze5
Jubk1i4PAMdxCH51+LvYQHFJEpSnjc8ueS7HZLv5ZuleE0IR9AuhQnnWIPhz4NKT
2ubCKE192+HILbmecGIxFHDgjO04WByvxSrOR8R617ZldZn4fwttADu+6K9Ukyu5
bfF6veU47TsN2gbttsGZphgZ/yqw0gKEYoCQUds3xvvHQvuKIwz+9CKeP5Go7nSe
5om77gP03O3Fu5K86bRHbk/dNMz14GeWKTp9Z7qos9qJ2W5toKGG5D9H5XqCWIM=
=44J+
-----END PGP SIGNATURE-----
