[Qgis-developer] Re: How to refresh QGIS layer (WFS Plugin)
Pulkit
pgoeol at yahoo.com
Mon Dec 12 23:00:10 EST 2011
I found a Refresh Menu option in QGIS, but the issue is that it always send WFS request with same view extent (bounding box) as it was in initially. Even after changing the view extent to some other location it never fetches features which were not visible at the time of loading.
Should I modify the WFS plugin to correct this behavior or is there any other way to solve this issue.
Thanks,
Pulkit Goel
To: "qgis-developer at lists.osgeo.org" <qgis-developer at lists.osgeo.org>
Sent: Monday, 12 December 2011 9:37 AM
Subject: How to refresh QGIS layer (WFS Plugin)
I'm a new QGIS user. I'm using WFS plugin to connect my QGIS client to a WFS server.
In
WFS plugin there is an option to restrict WFS to fetch features within
the current view extent. I'm using this functionality and it is working
fine, but the problem is that after loading a layer if I want to pan to
different area then it won't fetch the data again. So I want to know if
there is any option to refresh the layer so that it can fetch the data
according to new view extent.
Thanks,
Pulkit
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111213/cf7e77b6/attachment.html
