R: Re: [Qgis-developer] Trasform QgsVectorLayer proj4 to another
Richard Duivenvoorde
rdmailings at duif.net
Wed Dec 14 08:28:04 EST 2011
On 2011-12-14 13:55, francescoboccacci at libero.it wrote:
> Hi,
> i tried it but it works only with point tranformation. I would llike to
> tranform the entire vector layer.
> Do you have any suggestions?
Mmm, you are right, I only used it for one feature at the time.
Then I think you just have to loop over every feature in the layer that
you want to transform, and transform the geometry of each feature one by
one?
Given the QgsCoordinateTransform-object, you can transform one geometry
by using it's 'transform' method:
http://qgis.org/api/classQgsGeometry.html#46fd84e518cae4368aadeeac89574dfa
Some copy and paste from imagemapplugin.py:
destinationSrs = self.iface.mapCanvas().mapRenderer().destinationSrs()
layerSrs = self.iface.activeLayer().srs()
srsTransform = QgsCoordinateTransform(layerSrs, destinationSrs)
self.provider.select(self.provider.attributeIndexes(), mapCanvasExtent,
True, True)
feature = QgsFeature();
while self.rovider.nextFeature(feature):
feature.geom.transform(srsTransform)
See here:
http://www.qgis.org/pyqgis-cookbook/vector.html#writing-vector-layers
how to write a new file.
Devs, please let know if this is not ok....
By the way, I assume you are doing this from within a plugin or some
python code? Because qgis itself can do coordinatetransformations for
you when you use 'save layer as' .... in the gui.
HTH,
