[Qgis-developer] New plugin repository and 1.7.3
Borys Jurgiel
lists at borysjurgiel.pl
Sat Dec 17 08:25:10 EST 2011
QGIS <= 1.7 doesn't contain the repo. It wasn't removed, just never was added.
QGIS 1.8 branch and master before December 9 contain the wrong url, so I'm
pretty sure your wrong entry was added by one of them.
QGIS master (since Dec 9) contains the fixed url + automatically replaces the
wrong url with the corrected one.
So that problem should only affect people that run the affected master AND
didn't fix it by running newer master (after Dec 9).
Tim, could you please backport the file
python/plugins/plugin_installer/installer_data.py
from master to release-1_8 ?
Regards,
B.
Dnia piątek, 16 grudnia 2011 o 09:03:33 Sandro Santilli napisał(a):
> I'm running 1.7.3 and trying to get a new version of
> the QuickWKT plugin. New versions of the plugin are only
> available in the new repository, but the plugin installer
> seems to be unable to see _any_ plugin in the new repository.
> Is that expected behaviour ?
> That is, is plugin_installer 1.2.1 unable to parse the new XML
> for plugins repositories ?
> Mind you, I had a wrong url for the new official repository
> as it was installed by a development version of qgis from 1.7
> branch and had to manually tweak it to get it right:
> Bogus:
> "QGIS Official Repository 2" http://plugins.qgis.org/plugins
> Corrected as:
> "QGIS Official Repository 2" http://plugins.qgis.org/plugins/plugins.xml
> Also it seems that _current_ (1.7.3) plugin installer removed the new
> repository completely from the set of known official repositories, but
> such removal doesnt' affect the user configuration.
> Speaking of which: maybe the plugin installer should prevent you from
> dropping or editing repositories which are installed by code or allow
> you to "refresh" user configuration to match the one provided by new
> versions...
> --strk;
> ,------o-.
> | __/ | Thank you for PostGIS-2.0 Topology !
> | / 2.0 | http://www.pledgebank.com/postgistopology
> `-o------'
> Qgis-developer mailing list
