[Qgis-developer] absolut vs relative paths in qgs files
Anita Graser anitagraser at gmx.at
Mon Dec 19 07:41:24 EST 2011
I certainly cannot talk for everyone but the structure I've seen most of
the time was:
Keep all map data in a separate data folder. Project files are stored in
the project folder, which might have to be moved or renamed. Many projects
use the same base data, which should not be duplicated because files are
huge.
Relative paths are not an option for most of the use cases in such an
environment.
Best wishes,
Anita
On Mon, Dec 19, 2011 at 1:30 PM, Richard Duivenvoorde
<rdmailings at duif.net>wrote:
> On 2011-12-19 13:06, Nathan Woodrow wrote:
> > I think it's important to have both, they both have use cases  IMO it
> > would be good to be able to tell the project how to store each layer,
> Yes, and there is happily :-)
> -> Project Properties/Save paths
> It's just that seeing the issue about the wms, I had the feeling that we
> forced qgis to relative paths while maybe the (silent) majority wanted
> absolute paths as 'default'....
> Regards,
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111219/64bc8fe1/attachment.html
