[Qgis-developer] Built-in attribute form validation
bernhard.stroebl at jena.de
Tue Dec 20 07:10:30 EST 2011
Nathan,
I do like your idea, it in fact would reduce the need for custom Uis.
How about saving the check as part of the project or qml file similar to
the edit-widget option in the layer properties. Because for my feeling
that would be the place where it belongs and I cannot be sure that
anyone loading my qml file has the python file available in the same
path as I do.
Probably there is only a limited number of checks which cover the
majority of use cases e.g.
- NOT NULL
- range (for Numbers)
- range (for dates)
- max length (for strings)
- contains regex/string (for strings)
Multiple rules could be applied to any field in the fields tab of the
layer properties. For special cases you would still need a custom Ui,
though.
just my two cents
Bernhard
Am 20.12.2011 12:41, schrieb Nathan Woodrow:
> Hi all,
> I have been working on this idea over the last couple days which I think
> would be cool/handy to have in QGIS and I would be interested to get some
> feedback with what people think.
> The general idea is to add a form of field validation to the built-in
> attribute forms. The use case for this is pretty clear I think, being able
> to let the user/admin of any layer define validation rules to check against
> the data entered on the attribute form when the user presses OK providing
> instant feedback. I normally do this on my PostGIS tables but you don't
> get errors until you try and commit the data and even then it's a simple
> "there is a error", if you have added more then 1 item you have to check
> each one to work out what is wrong, and this method only applies to a
> PostGIS layer. The idea I have been drafting would work on any layer, as
> it's at the QGIS level vs at the datasource level.
> My idea is to use simple a simple Python file with basic functions that
> will be called for each field in the attribute form that is editable. I'm
> a big fan of convention over configuration so my idea uses conventions to
> define what functions are used to validate what fields. The function will
> return False and an error message that can be shown to the user if
> something is wrong.
> The functions use the following syntax: validate{FieldName} or
> validate{FieldIndex} for naming (plus some other styles) e.g
> def validateName():
> if value == "":
> return (False,"Name can't be NULL")
> return True
> You would place the function in a python file e.g PeopleRules.py and then
> tell QGIS to use this file to look for validation rules, pretty much the
> same as we do now for having custom Python forms.
> Overview of logic:
> 1. Define Python file with rules
> 2. Tell QGIS to use the rules file for the layer.
> 3. Open attribute form
> 4. Edit some values
> 5. Press OK
> 6. QGIS calls each function in the rules file to validate each field
> that is defined with a rule
> 7. If there are errors: cancel the accept() action and show the errors.
> If there are no errors go though like normal.
> My thoughts for using Python are:
> - Easy to read and write
> - Not limited to what we have in QgsExpression and easier to expand.
> - Can add documentation to validation rules.
> - Can add more complex validation rules e.g. regex, parsing, database
> checks etc
> My overall goal with this is to reduce the need to create custom Python Qt
> forms when doing data entry, and doing validation is one of the reasons I
> tend to make custom Python Qt forms but then you loose the ease of QGIS
> doing most of the form work for you.
> I have attached two files which have a example of what the idea is.
> fieldChecks.py is an example rules file with comments to explain each
> section, runMe.py has the logic for reading and executing the rules for
> each field. Run: python runMe.py to see the running logic and output.
> What love to get peoples thoughts about this, users and devs a like.
> - Nathan
> ________ Information from NOD32 ________
> This message was checked by NOD32 Antivirus System for Linux Mail Server.
> http://www.nod32.com
> Qgis-developer mailing list
