[Qgis-developer] QGIS Framework for web and online shapefile
viewer
Mohammed Rashad
mohammedrashadkm at gmail.com
Fri Feb 4 09:01:25 EST 2011
I got minimal qgis gui files
qgsmapcanvas.h/.cpp
qgsmapcanvasmap.h/.cpp
Now I need minimal qgis core files. but I cant get the minimal files as I
got for gui.
Can anyone help me out.
On Fri, Feb 4, 2011 at 6:50 PM, Mohammed Rashad
<mohammedrashadkm at gmail.com>wrote:
> On Fri, Feb 4, 2011 at 6:35 PM, Marco Hugentobler <
> marco.hugentobler at sourcepole.ch> wrote:
>> Hi Mohammed
>> Yes, it is possible to do rendering with QGIS independent of GUI. You
>> could
>> take a look at the code for the server in qgis trunk (in the src/mapserver
>> directory). Basically you use QgsMapRenderer, add the layers to it and
>> render
>> into a Qt paint device (usually QImage for GUI independant tasks).
> how to it works.? How to check the rendering by the source in src/mapserver
>> > does QGIS can be used as a framework in our application?
>> I hope so. Please also consider that the QGIS libraries are GPL license (
>> not
>> LGPL ).
>> I have no problem with license. the problem is getting qgis out of Qt4Gui.
>> Regards,
>> Marco
>> Am Freitag, 4. Februar 2011, um 13.55:33 schrieb Mohammed Rashad:
>> > Hi all,
>> > How to use QGIS as a framework to develop desktop based gis application
>> > changing the gui part(qt4_gui) and reusing qtcore, network xml and other
>> > libs.
>> > here is an online shapefile viewer which I had done reading shapefile
>> using
>> > OGR and rendered using Wt.
>> > http://lsi.iiit.ac.in/lsi/shpviewer/
>> > Here the shapefile is directly rendered without mapserver or anything.
>> only
>> > library we used is GDAL and rendering is done by Wt
>> > Please check it. for testing we have demo data attached with this mail.
>> you
>> > can also try your own data.
>> > Now I am coming to the point.
>> > Till now we have not used any code from QGIS.
>> > but we tried creating and layer and checking it if it is valid. upto
>> that
>> > extent we can reuse QGIS Code.
>> > this code works on web and prints a "Layer is valid"
>> > QgsVectorLayer * mypLayer = new QgsVectorLayer("/home/rashadkm/data",
>> > "point_data", myProviderName);
>> > if (mypLayer->isValid())
>> > cout << "Layer is valid" << endl;
>> > else
>> > cout <<"Layer is NOT valid" << endl;
>> > So My question is
>> > In QGIS code is seperated as gui core etc..
>> > so for starting the work keeping QGIS as a backend we need minimal gui
>> code
>> > which display a vector (or just shapefiles).
>> > If someone can help me with this I can do the rest of coding needed for
>> Wt
>> > Only I need is a very minimal source code and files which can do
>> rendering
>> > in Qt.
>> > Looking forward your comments and suggestions.
>> > rashadkm * gmail [dot] com
>> Dr. Marco Hugentobler
>> Sourcepole - Linux & Open Source Solutions
>> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>> Technical Advisor QGIS Project Steering Committee
> Rashad
Rashad
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110204/0640f9de/attachment-0001.html
