[Qgis-developer] A roadmap to QGIS 2.0
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Fri Feb 4 14:50:03 EST 2011
Hi Martin
> I think boost.geometry library
> (former GGL) is a strong candidate for the backend
This library looks very promising. Seems we could just use the Qt classes,
e.g. QPolygonF for polygon rings
(http://geometrylibrary.geodan.nl/x01__qt__example_8cpp-example.html). Like
this, there could be a very fast transfer from the data provider to the
rendering.
But first the threading, the raster providers and the table joins.... :-)
Regards,
Marco
Am Freitag, 4. Februar 2011, um 13.32:38 schrieb Martin Dobias:
> Hi Juergen
> On Fri, Feb 4, 2011 at 11:27 AM, Jürgen E. <jef at norbit.de> wrote:
> > Did I miss Martins comments on that? I didn't find any.
> Sorry for not joining the discussion, first I was too busy, then I've
> been away, so after 14 days I thought it's too late to join the
> discussion :-)
> Anyway I'm going to share my thoughts now.
> I agree with Tim's goals for the 2.0 release. I also agree with the
> point that we should do few releases (e.g. 1.9.x) before 2.0 that
> would incrementally throw out old stuff and bring a lot of polish, so
> that 2.0 will be merely a renamed 1.9.x version - in order to have a
> solid release, not a feature-packed unstable release. (Probably many
> people will give 2.0 a try and if it's buggy they'll wait again for
> 3.0). At the same time I would be a bit more modest regarding the
> timeline, but as Tim noted, it looks like everyone has a different
> opinion on that and his plan is quite reasonable.
> One of the many things that I would like to see in 2.0 is a reworked
> geometry class. I hope everyone who knows the inner working of
> QgsGeometry will agree with me :-) I think boost.geometry library
> (former GGL) is a strong candidate for the backend, since it starts to
> mature and has several advantages over GEOS:
> - allows to use our own geometry classes - no need to copy geometries
> back and forth
> - it's pure header library - so it's only build dependency, not
> runtime dependency
> It could miss some functionality that is available in geos, though - I
> haven't done an extensive comparison yet.
> One of the important things is how/when to merge the threading branch.
> I know that just few people tried it, so I didn't get much feedback
> apart from Marco's and Pirmin's comments. As of now, I am aware of
> just one important blocker that prevents me to merge the branch (there
> will be probably few bugs, but I don't think of them as critical).
> The blocker is the issue of threading vs python. Python in general is
> not a great friend with threading - it has an infamous Global
> Interpreter Lock (GIL) which ensures that only one thread in
> application can run Python code. To enable threaded applications, GIL
> is unlocked periodically (when running python code) and locked again
> to give other threads a chance to run The problem in QGIS shows up if
> any part of the rendering stack is in Python. That could be a custom
> symbol layer instance, custom renderer or a custom "plugin" layer.
> Rendering freezes at that point, because Python code is waiting for
> GIL, but it doesn't receive it since no Python code is running either
> (in main thread) that could unlock the GIL. The question is how to
> handle this situation. I had few ideas how to solve this:
> - run periodically some python code in main thread, so GIL could be
> acquired by rendering thread. This is lame: if called often, it eats a
> lot of cpu, if called rarely the code in rendering thread progresses
> slowly.
> - unlock GIL manually when rendering starts and lock it again when
> rendering finished. Until now I have failed to produce a result which
> wouldn't crash/deadlock when tried running python code in main thread
> while rendering thread is running python code. (As someone noted on
> one mailing list, python documentation for this topic is clear as
> mud).
> - identify which parts of the rendering stack are in python and
> explicitly run rendering of these layers in main branch. This would
> actually avoid the whole problem and might work fine. I haven't
> investigated this option yet, I'm mainly interested in an simple way
> how to find out if a class is implemented in python.
> I would appreciate any comments for that.
> Among the smaller issues, there should be more aggressive locking to
> prevent data corruption when rendering and modifying the data at the
> same time (e.g. vector edit buffer, raster/vector layer properties). I
> also had to remove connection pooling for postgis layers from one
> server, since it's not possible to read data for more than one layer
> at once from one connection. But these things can be fixed as the time
> goes.
> > Did anyone try merges yet?
> I haven't tried to merge the code yet.
> I would recommend to merge Radim's raster providers branch prior to
> the threading branch, since it's much simpler. However then we will
> have to make sure that rasters work correctly with the threading.
> > I've was going to try - but I all I managed so far is to get git (and
> > that took quite some amount of persuasiveness to get there - git rookie
> > here) to checkout trunk, rasterproviders, threading and table branch
> > into one repository.
> > I'd like to work more on the forms stuff and I think the table join
> > branch could be a prerequisite for that.
> > Anything I can do to help with the merges?
> It will be useful to merge the table join branch to threading branch
> first, and then update it with the zillion of commits that happened in
> trunk in meanwhile. With that help, I think threading branch could be
> merged to trunk much sooner. I would really appreciate that!
> Regards
> Martin
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Churerstr. 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
