[Qgis-developer] Problems using QgsVectorLayer::selectedFeatures()
Federico J. Fernández
federico.fernandez at gmail.com
Mon Feb 7 07:54:23 EST 2011
> On Mon, Feb 7, 2011 at 12:40 PM, Federico J. Fernández
> <federico.fernandez at gmail.com> wrote:
> > QgsFeatureList &featureList = this->currentLayer->selectedFeatures();
> You only store reference to a temporary list returned by
> selectedFeatures(). That list is destroyed when that function
> terminates, so you have an invalid reference. Store the whole list
> instead, not just that reference:
> QgsFeatureList featureList = .... ;
> Your original post actually listed the correct version (without the
> reference '&'), that's why it wasn't clear where's your problem.
> By the way, QGIS contains a map tool for merging features (in
> src/app), so you could save your work by using that code instead of
> writing similar code again.
Sorry for the mistake Martin, it gives an exception with and without the &.
I know about the QGIS tool, my version is copied from that code, but without
some layer checks that are not neede in my application.
Thanks again for your help!
fede
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110207/f120bbec/attachment-0001.html
