[Qgis-developer] qgis web
Richard Duivenvoorde rdmailings at duif.net
Sun Feb 13 06:06:09 EST 2011
Mohammed Rashad wrote:
> How to render a shapefile to an image file so that it can be reused on a
> web page.
> Anyone please send a me a minimal code or tell me where and what to
> modify. I looked src/mapserver folder but I cant get the code for it
> Atleast please tell me the file to modify to render a vector file(shape)
> to an image file
you're not very clear what exactly you want.
But, if you want a one time imagefile of a map from a shapefile, use
'Save as Image' from the File menu.
If you want to do some python coding for a plugin, please have a look in
to for example the "Html Image Map plugin", that one saves an image from
current map. Minimal code from Python console in a running qgis:
qgis.utils.iface.mapCanvas().saveAsImage("/tmp/mymap.png")
If you want a server process generating maps from the (changing?)
shapefile, you need a WMS (Web Mapping Server). You can use QGIS
mapserver for that: http://karlinapp.ethz.ch/qgis_wms/. But even more
famous ones like Minnesote Mapserver (mapserver.org), or Geoserver
(geoserver.org).
Regards,
