[Qgis-developer] QGIS Source Compile and Plugin Development
sailmcm
sailmcm at yahoo.com
Mon Feb 14 18:40:38 EST 2011
Thanks Richard. I do use python. But I have standalone c++ code I want to use in qgis. I also think it more reliable to use c.
Thanks again for your help.
Richard Duivenvoorde <rdmailings at duif.net> wrote:
>maaza mekuria wrote:
>> Anyone knows or has documentation to help me progress with the plugin
>> development?
>> Here is my status.
>> I use windows XP and Visual C++ Express 2008. I have a working copy of a
>> build that I was able to compile QGIS. I tried inserting a project and
>> making a plugin from scratch, and I find it needs a lot of other
>> libraries. I then tried copying an existing plugin and tried to modify
>> it, and it seems there are too many files that are needed to compile
>> plugin and it just keeps giving error message after another. Do we have
>> a minimum number set of headers/libraries/files that are required to
>> compile a plugin?
>> Is there any guide for the windows platform on plugin development?
>> I have looked at the Linux plugin sample given in the introduction
>> developer document and have tried to follow it in Windows and I have not
>> been able to compile the plugin.
>If you want to develop a python(!) plugin you do not need to compile QGIS.
>You can install a stable qgis-version on you machine, and if you see the
> python console in the Plugins menu, you have all the tools to write a
>plugin (without it's own dialog though).
>Please read http://www.qgis.org/wiki/Writing_Python_Plugins (see the
>Windows remarks at the bottom and use one of the 'generate myfirst
>plugin pages').
>IF you want to have your own dialogs, you will need to install QT and
>it's python bindings, because using QT-developer you can then generate
>the neccesary .ui files for you dialogs.
>Regards,
