[Qgis-developer] Send us your tips!
Tim Sutton lists at linfiniti.com
Sat Feb 19 05:02:15 EST 2011
Hi
Yesterday I added a 'tip of the day' type dialog that appears when
QGIS starts. You have probably have seen a similar feature in other
applications. And no, before you ask, we are not going to implement a
'Mr. Paperclip' function next :-). Right now the tip list is rather
basic so I would like to invite everyone to submit your favourite
little tips for QGIS. Here are some guidelines:
- The tip should have a short title
- The tip content should be short - one or two paragraphs
- Simple HTML formatting can be used for the tip, including links, lists etc.
- Tips should be broadly useful and perhaps reveal functionality that
users may have otherwise overlooked.
Here is an example submission:
Title: Quick access to project properties
Content: You can quickly access the project properties dialog by
clicking on the icon in the bottom right corner of the window in the
status bar area.
If you are a developer, you can add tips directly to
src/app/qgstipfactory.cpp - it should be self explanatory what to do
when you look at the source.
Regards
Tim
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
