[Qgis-developer] ESRI File Geodatabase (*.gdb) API for Window
and Linux now
Frank Warmerdam
warmerdam at pobox.com
Sun Feb 20 17:26:28 EST 2011
On 11-02-20 05:13 PM, Noli Sicad wrote:
> JFYI.
> ESRI File Geodatabase (*.gdb) API for Window and Linux now. If I
> understand it correctly, we can read and write FGDB (*.gdb) using this
> API.
> http://blogs.esri.com/Dev/blogs/geodatabase/archive/2011/02/11/File-geodatabase-API-Beta-2-now-available-for-Linux.aspx
> Any plans to support it in QGIS 2.0?
Noli,
Ragi Burhum has done the bulk of an implementation of an OGR provider
based on the ESRI FileGDB SDK. I think there may still be some limits
on the types of geometry supported but that should be easily corrected.
This work is in GDAL/OGR "trunk".
gdal/ogr/ogrsf_frmts/filegdb/
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
