[Qgis-developer] Issue saving shapefiles with REAL15 values
Paolo Cavallini
cavallini at faunalia.it
Tue Feb 22 07:19:11 EST 2011
Il giorno mar, 22/02/2011 alle 13.16 +0100, Anita Graser ha scritto:
> I have a shapefile containing fields of type REAL15. I'd like to cut an
> area of interest out of this shapefile using QGIS "Save as ..." function.
> The resulting shapefile still has fields of type REAL15 but the contained
> values are botched, e.g. 10400000603695 becomes -2147483648.
> I'm uncertain whether the problem lies with GDAL or QGIS' use of GDAL.
Which versions?
> It would be great if this problem could be resolved. Unfortunately, I
> can't share the original (commercial) dataset.
You can extract just one record, and share that one.
All the best.
http://www.faunalia.it/pc
