[Qgis-developer] Raster providers
Tim Sutton
lists at linfiniti.com
Thu Feb 24 04:00:07 EST 2011
Hi Radim
I did some testing too. Having otf projection is coool! Id did run
into some problems with my paletted image[1] though.
If I open the image in QGIS default session (i.e. no OTF projection)
it displays fine [2].
If I enabled OTF Projection (using 900913 Google Mercator) the image
displays as all grey [3].
If I set the CRS to the native image projection (EPSG:32734), the
image does not show at all.
I still need to test with other image types properly but thought I
would give you this feedback so long.
Also I noted that for greyscale images they always seem to load with
min 0 / max 0 and I have to manually go into properties to load them
from the layer.
[1] http://linfiniti.com/downloads/Toposheet.tif.bz2
[2] http://imgur.com/JHOvt
[3] http://imgur.com/NxB7z
By the way if anyone else is using git-svn and wanting to test Radims
branch, this was the process I used to add it as a local and remote
branch in my local repo:
git config --add svn-remote.raster-providers.url
https://svn.osgeo.org/qgis/branches/raster-providers
git config --add svn-remote.raster-providers.fetch
:refs/remotes/raster-providers
git svn fetch raster-providers -r 15231
git checkout -b raster-providers -t raster-providers
git svn rebase raster-providers
Thanks to Juergen for pointing me to the relevant crannie in the
internet that showed how to do that.
Regards
Tim
On Mon, Feb 21, 2011 at 4:04 PM, Radim Blazek <radim.blazek at gmail.com> wrote:
> Hi have fixed some known problems:
> - short data types are represented by longer types to get space for
> nulls (the problem Marco found)
> - avoid statistics calculation on raster load (reported by John C. Tull)
> - properties are enabled according provider capabilities
> Please test.
> Radim
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
