[Qgis-developer] When a code freeze?
Tim Sutton
lists at linfiniti.com
Fri Feb 25 15:43:30 EST 2011
Hi
On Fri, Feb 25, 2011 at 10:10 PM, Sergey Yakushev <yakushevs at list.ru> wrote:
> Fri, 25 Feb 2011 18:33:38 +0200 письмо от Tim Sutton <lists at linfiniti.com>:
>> > Can you make it
>> > work in some default way so that configuration of the plugin is not
>> > mandatory?
> It isn't good idea, I think. User looks at the the settings window, and understands how the plugin works.
Ok maybe at least just popup the settings dialog then.
Also I think the following label changes should be made in that dialog:
Direct direction -> Value for forward direction
Reverse direction -> Value for reverse direction
Both direction -> Value for two-way direction
Maybe it would also be good to make those combos where you pick the
value rather than text box where the user needs to know the values a
priori.
Regards
Tim
>> > Thanks for this awesome tool!
>> Oh one other suggestion is just to have an hourglass or progress bar
>> so the user understands that it is busy calculating!
> I thought about it. Many people tell me about it. I will do it to release qgis.
> It is "fix GUI before code freeze".
>> Thanks again!
> С уважением Якушев Сергей yakushevs at list.ru
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
