[saga-gis-developer] [Qgis-developer] Re: QGIS plugin
Noli Sicad
nsicad at gmail.com
Mon Jan 3 04:29:52 EST 2011
This is the reason when I read the documentation, it does not make sense.
Paolo, I think we have to delete the entry in the ticket and replace
with this one.
Source and Python Bindings below.
http://sourceforge.net/projects/saga-gis/files/SAGA%20-%202.0/SAGA%202.0.6/
Johan, thanks for the correction,
Noli
On 1/3/11, Johan Van de Wauw <johan.vandewauw at gmail.com> wrote:
> You are confusing saga (an api for grid computing
> http://saga.cct.lsu.edu/) with saga gis ( http://www.saga-gis.org ).
> But: saga gis also has a python api based on swig.
> Some examples are here:
> http://sourceforge.net/apps/trac/saga-gis/raw-attachment/wiki/MiscWikiFiles/saga_2_python.zip
> In case people are interested: I have a script which parses the module
> parameters to create some test scripts which can be useful as a start
> for such a module (attached - bear in mind that this is the first and
> only thing I ever wrote in python) - I'll check if everything works ok
> with the current version and try to add some documentation on how to
> build the saga python extensions to the wiki and then ping back.
> Johan
> On Mon, Jan 3, 2011 at 8:29 AM, Paolo Cavallini <cavallini at faunalia.it>
> wrote:
>> Il giorno lun, 03/01/2011 alle 12.32 +1100, Noli Sicad ha scritto:
>>> It seems that there is already SAGA Python Bindings.
>> Thanks. Added to:
>> https://trac.osgeo.org/qgis/ticket/3383
>> Any taker?
>> All the best.
>> http://www.faunalia.it/pc
>> Learn how Oracle Real Application Clusters (RAC) One Node allows customers
>> to consolidate database storage, standardize their database environment,
>> and,
>> should the need arise, upgrade to a full multi-node Oracle RAC database
>> without downtime or disruption
>> http://p.sf.net/sfu/oracle-sfdevnl
>> saga-gis-developer mailing list
>> saga-gis-developer at lists.sourceforge.net
>> https://lists.sourceforge.net/lists/listinfo/saga-gis-developer
