[Qgis-developer] GDAL Version inside qgis python API
Maurício de Paulo
mauricio.dev at gmail.com
Mon Jan 3 14:43:02 EST 2011
Nice!
Now I can see that there is a report on the same about with the real gdal
number.
Great! I've tested again and now wktraster plugin works on windows!
I'm going to do some tests with non-standard files now.
Best regards,
Mauricio
On Mon, Jan 3, 2011 at 5:19 PM, Jürgen E. <jef at norbit.de> wrote:
> Hi Maurício,
> On Mon, 03. Jan 2011 at 16:36:59 -0200, Maurício de Paulo wrote:
> > Now i've looked at gdal_tools code and it calls the module gdal and
> checks
> > it's version. Seems odd to know that the module and qgis doesn't use the
> > same versions on a OSGeo4W installation.
> > On my laptop qgis reports (on the about screen) gdal 1.5.3 and
> python-gdal
> > reports 1.7.3.
> The output in the about screen is wrong. QGIS uses 1.7 on OSGeo4W.
> But if you install both gdal and gdal17 the about box will pickup the gdal
> include from the 1.5 directory - just a cosmetic issue.
> > Is there any way to get to know what kind of files does qgis open as
> raster?
> You mean which DLLs it's linked against? Checkout dependencywalker[1].
> Jürgen
> [1] http://www.dependencywalker.com/
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
Mauricio de Paulo
Engenheiro Cartografo
MapeandoOBrasil <http://mapeandoobrasil.blogspot.com>
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110103/9eec9814/attachment.html
